I understand that you're experiencing a **black screen isssue** with your **Meta Quest 2** during startup. Let's troubleshoot this together! Here are some steps you can try:
1. **Hard reset**:
- Hold down the **power** and **volume down** buttons on your Meta Quest 2 for at least **10 seconds** or until the boot screen appears.
- Use the volume buttons to scroll to **"Boot device"** and select it using the power button².
2. **Factory Reset** (if needed):
- Press and hold the **power** and **volume down** buttons simultaneously until your Quest turns on.
- Navigate to **"Factory reset"** using the volume buttons and press the power button.
- Finally, select **"Yes, erase and factory reset"**³.
3. **Check Graphics Settings**:
- If you're using a hybrid graphics card setup (common in gaming laptops), where some processes run on the dedicated card while others run on integrated graphics, it might cause issues with Oculus Link.
- Try changing all Oculus files to **"High Performance"** in Windows' direct graphics settings instead of using Nvidia's control panel¹.
A voté
Annuler
Indice
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter un commentaire à cette contribution » pour le déplacer.
