Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Introduite en 2016 lors du lancement de la Xbox One S, la manette Xbox One ajoute le support Bluetooth pour Windows 10. C'est la manette grand public actuellement vendue par Microsoft. Elle rectifie un nombre de défauts de conception des manettes modèles 1537/1697 et elle est beaucoup plus fiable.
Why analogue stick go up and down not left and right after repair?
Just a quick one if anyone can help. Its about stick drift on this Xbox One controller. On the left stick after being replaced the drift disappeared. But another issue appeared, the stick on gamepad tester only goes up and down, not left to right.
I replaced another brand new analogue and still comes up with the same problem.
Any Ideas what this could be ?
Thanks,
Taro
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Solution retenue
Hi Taro!
Did you replaced it with specific Analog sticks for the Xbox controllers? I know that also the PS4 ones fit and exactly look the same, but they can differ.
Here you can buy it: Xbox Series X/S Controller Joystick
If you used those sticks, please replace the other stick as well and see what happens. Also re-check your solder work to make sure that all is OK.
Image Replace one controller joystick compatible with an Xbox Series S or Series X controller. Fix issues like drifting or an unresponsive joystick.
Produit
$14.99
Indice 2
7 commentaires:
Hello Koppie007!
I didn't expect a reply, nevermind a reply so soon!
That is interesting you mention that. I have a bag of analogs. I have checked the guide on amazon you sent me. It looks like I have only 1 XB1 analog and the rest are PS4 analogs. lol... when I get time tomorrow I will swap those analogs out and let you know the result.
Thanks for your time !
Taro
par
Hi Taro!
My pleasure! Glad that I could help :)! If you have any questions, just let me know! Good luck and let us know how it goes :D!
par
Hello!
I managed to get round to doing it, great help it gave me some insight on different analogues. I did replace it with the right one (Gray under the bottom for Xbox one controller) Joints are all ok but it still seems to only go up and down not left and right =/. As far as my knowledge goes, would it be a faulty PCB possibly?
Many Thanks in advance,
Taro
par
@tarosquire It probably is a faulty circuit board if two or three different sticks have come up negative i belive there is a guide on how to replace the motherboard (Remplacement de la carte mère inférieure de la manette sans fil Xbox One modèle 1708) and you might just have to do that
par
Yeah, when you have replaced it multiple times now (for the correct ones), it must be motherboard related… sorry!
par
Voir 2 commentaires en plus
Ajouter une réponse
Taro sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 33
30 derniers jours : 110
Total : 1,749
