Aller au contenu principal
Informations sur la réparation, le démontage et le diagnostic de la Xbox Series S, la nouvelle console de jeu numérique de Microsoft. La Xbox Series S est sortie en même temps que sa grande sœur plus puissante, la Xbox Series X, le 10 novembre 2020.
Xbox series s turns off 2 seconds after I turn it on?
Why does my xbox series s turn off about two seconds after I turn it on with no display I think it could be the ssd do I need to buy a new on if so were do I get the xbox os from.
Répondre à cette question J'ai le même problème
Indice 1
1 commentaire:
@braydenc what makes you think it is the SSD? What have you checked?
par
Ajouter un commentaire
1 Réponse
It seems like your Xbox Series S might be shutting down due to an issue with its SSD. Try these steps:
  1. Check all cables for secure connections.
  2. Perform a power cycle by unplugging for 30 seconds.
  3. Consider a factory reset via Settings > System > Console info > Reset console.
If the issue persists, you may need to replace the SSD.
Indice 0
1 commentaire:
@tabathakang AI, got a question for you. How do you suggest to perform factory reset if the xBox does not come on? AI would not check anything else but would go right to the SSD? Why? AI can't think for itself and uses regurgitated Google stuff :-) Start using your own brain (algorithm). LMBO so weak and predictable.
par
Ajouter une réponse
Brayden c sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 11
Total : 263
