How can I repair my laptop battery
My laptop battery get slowly charge and get fastly discharge
So this isn't that clear of the problem, when did this become an issue? What were you doing when you noticed? Are you gaming/using high performance mode? Is your brightness all the way up? Are you using the correct charger the one that came with it from the manufacturer? You can't really repair a battery unless you are a professional and have the tools, you would be better off just buying a new battery.
What CodyW said. But note that LT batteries usually go bad because 1 or 2 of the cells (18650) go bad. There are still 4-6 more that are good. I take them apart and use the good ones for my flashlights and other things that use 18650 cells.
Still probably cheaper to just replace the battery.
Amazon or E-bay have aftermarket ones that are usually inexpensive.
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 12
Total : 53
