Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le smartphone OnePlus de 5ème génération (OP5) est sorti le 20 juin 2017. Il s'agit du successeur du OnePlus 3T et du prédécesseur du OnePlus 5T.
Touch died one day after battery replacement
I replaced the battery myself, folowing the guide on the oneplus 5 here. Everything went well and worked when i was done. I am 100% shure the touch worked after i was done. I left the phone charging over night to start the battery calibration. When i checked the phone the next day the touch wasn't working at all, no reaction, nothing, not in the OS or in the recovery screen. It seems like damage from the battery replacement but i find it strange that it only stoped working a day after. I reopend the phone to checked and reseat the connectors that need to be unpluged for the battery replacement, no change. I updated the OS and reset to factory settings wich also didn't help (i use LineageOS). Any ideas on how to fix this or what the problem even is?
additional info:
-I used 70% isopropyl alcohol on the battery to remove it, i was carefull to remove all fluid i could see afterwards -could it be water damage?
-the screws for the speaker got mixed up on reassembly -are they not all the same lenght?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
The fix seems to be to clear the system cache from the recovery mode.
When i searched online for solutions, it seems like the OnePlus 5 had problems with the touchscreen somewhat often.
This fix was one of the suggested solutions.
Good to know my screen isn't broken.
Indice 0
Ajouter une réponse
Dorian sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 10
Total : 216
