Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Tout sur la réparation iPhone 14 Plus. Ce nouveau format Apple pour la gamme 14 comprend un écran OLED de 6,7 pouces – comme le Pro Max – mais les mêmes caractéristiques que l'iPhone 14 avec une configuration à double caméra et la puce Bionic A15 au processeur graphique à 5 cœurs.
What might be the possible soln to this log below
Afficher le contenu de l'image :
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
I currently have this same issue. 0x400000 is for the wireless charging coil flex. My rear cameras and flash are not working either, do yours? I have tried replacing the wireless charging coil already and it did not fix this kernel panic.
Indice 1
2 commentaires:
Unfortunately yes I have the same problem , no flash and no back panel. I don't know what to do to make it work . I haven't found a solution yet . I tried to put an aftermarket rear panel on it , but it was probably the panel that was faulty . Did you try to fix it with a factory part ?
par
Yes I ordered a new rear camera and wireless coil to see if either part was faulty and causing the others not to work. I also tried 2 different back panels and none of the parts fixed the issue with panic. Im starting to think that its not the camera or the wireless charging flex and actually an issue with the logic board that has disabled those circuits. I have done multiple restores even with the new parts installed and that didn't fix it so Im out of ideas.
par
Ajouter une réponse
Ernő Németh sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 22
Total : 356
