Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter un commentaire à cette contribution » pour le déplacer.
3 commentaires:
Can we get anymore information on this? Like what happend, How mad was the crash?
Well I wouldn’t call it a crash. There was very very minimal damage to the front bumper, only visible after close inspection. I could still drive afterwards, the only problem being that my horn was no longer working. After I got home I checked and they were both still there, the connection looked intact and that left me with just the fuse box to check. Sadly I couldn’t pull out the fuse. So I am just wondering what else might have gone wrong
If your Toyota Corolla's horn stops working after a bump, you can investigate several potential causes. First, check the fuse associated with the horn circuit. If blown, replace it. If damaged, inspect the wiring harness. If the horn relay is faulty, replace it. If the horn assembly is damaged, disconnect it from the wiring harness and test it. If the steering wheel and airbag components are affected, have a professional inspect and repair them. If you can't resolve the issue yourself, visit a qualified mechanic or automotive technician.
par Braiden Hill
par Daniel Jekennu
par Asha Kanta Sharma
