Replaced battery says "UNAUTHENTIC BATTERY DETECTED" How do I stop it?
After replacing the battery, Windows gives a popup
How do I stop it?
How do I stop it?
The complicating factor is that there are many versions of the "Surface Diagnostic Toolkit". You need to use the version intended for Commercial Repairs - which is available as a ZIP over here: https://www.microsoft.com/en-us/download...
When you run it, also make sure to choose 'Repair' instead of 'Diagnostic'. Then you will have the option to perform a Battery Verification. It will try to contact Microsoft servers to authenticate the new battery.
There are a number of posts about this. Do an internet search for "work around for unauthentic battery detected".
I tried that, almost all the results say ignore it, or try the following steps which do not work.
"1. Force the device to shut down and restart
Press and hold down the power button until your Surface shuts down and restarts and you see the Windows logo screen (about 20 seconds), then release the power button.
2. Check Windows Updates
Go to Settings >> Update and Security >> Windows updates >> Check for updates
3. Run Surface Diagnostic Toolkit
See: Fix common Surface problems using the Surface Diagnostic Toolkit (microsoft.com)
4. Remove and reinstall battery driver.
From Device Manager, expand the Batteries category.
Double-tap or double-click Microsoft ACPI-Compliant Control Method Battery, select the Driver tab, and select Uninstall > OK. Then restart your device."
Before I change my battery, was this ever resolved? The post from iFixit says that it will try to contact MS servers but what happens after that?
I had to find the answer myself from experimenting
– Connect USB with the Surface Diagnostic Toolkit (SDT)
(Make sure it's the newest version [From https://www.microsoft.com/en-us/download...])
-Install Surface Management Extension (IMPORTANT)
– Launch SDT, select Repair from the drop-down menu. Next, select Repair Setup & Validation to enter the selection screen. Run the Battery Repair (Setup) to put your device into repair mode. Follow all on-screen instructions & allow the device to shut down when prompted. Disconnect the Power Supply & remove the USB drive before proceeding forward.
-Replace Battery
-Power on Device & Charge the battery to 50% minimum.
-Launch SDT from the USB
-Run Battery Authentication
– From the SDT launch screen, select Repair from the drop-down menu. Next, select Repair Setup & Validation to enter the selection screen. Select the Battery Repair (Validation) tool & follow the on-screen prompts until a successful authentication is completed.
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 64
Total : 2,026
