Aller au contenu principal
This instant camera from Fujifilm now boasts a slimmer and lighter body than previous revisions. The Mini 8 helps the photographer by alerting them the recommended aperture. It also has a High-Key flash mode which helps the photographer attain soft portraits for a stunning look.
20 questions Voir tout
Cartridge is stuck, lights not on
I was trying out the camera for the first time but the first protective film layer didnt even come out after the shutter sound. And now its stuck within the camera. At first the lights were still blinking. I heard that switching the batteries while the camera was still on might help. Tried it, didnt work. Now not even the lights are on. I cant take the films out either because the protective cartridge is so deep inside. I dont know what to do...
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
1 commentaire
man... is anyone even out there anymore...
par
Ajouter un commentaire
1 Réponse
Solution retenue
okay guys, listen up. yes ive been thinking about this problem since i posted this six hours ago.
btw brother, read this only if replacing the batteries didnt work for you. ive explained the correct way to place them on my 2nd point
anw, what did i do?
1) i kinda forcefully pulled out the film box behind. it was jammed pretty badly and it was almost impossible to pull out the film box. the first protective layer was barely out of the film box yes. just try to get a hold on the two holes on the film box and get the lower part of the film box out just a little bit, then wiggle it left and right while still pulling it out gently. DO THIS ONLY AND ONLY IF REPLACING THE BATTERIES DIDNT WORK FOR YOU.
2) and as for the reason why my camera lights blinking died, my dum ahh placed the batteries wrong.
inner most battery should be placed +ve bottom -ve top
outer most battery should be placed +ve top -ve bottom
$@$* fixed itself after i did these tho i am yet to try out the camera again.
thank you for coming to my ted talk. may those who still use this camera in 2024 find peace and happiness.
Indice 0
Ajouter une réponse
yoku oboenai sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 15
30 derniers jours : 31
Total : 263
