Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le Meta Quest Pro est un système de réalité virtuelle sorti le 25 octobre 2022. Il s'agit du premier casque Meta à utiliser des optiques « pancake ».
Do Quest Pro controllers use the same joystick part as Quest 2?
Hi, I hope someone who has experience disassembling or repairing Quest Pro and Quest 2 / 3 controllers can answer this.
I've heard that Quest 2 and 3 controllers use an identical part for their analogue sticks, but can't find any info on QPro controllers.
This is important because Quest 2 replacement sticks are currently available from Amazon and elsewhere, but there's nothing labeled for Q3 and QPro as far as I know.
Thanks
Edit: Replacements labeled for Q3 are now available.
I also found this reddit thread:
https://www.reddit.com/r/oculus/comments...
"Posting a year later for others looking for confirmation.
The quest 2 thumbstick component is compatible with the pro touch controller, go ahead and replace with quest 2 part.
However, the capacitive spring that is inside of the thumbsticks are not compatible - take care not to deform or stretch the pro controller spring when disassembling the controller to replace the stick assembly.
Good luck, its a complicated teardown."
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Solution retenue
Indice 1
Ajouter une réponse
Jeff sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 27
30 derniers jours : 131
Total : 2,394
