The front of the power adapter cable is broken, it does not work
The front of the power adapter cable is broken, it does not work, My laptop is out of battery so I can't turn it on, help me
@furkanergun either you replace the complete power adapter or you can simply replace the front barrel adapter. You’ll need a 4mm (outside diameter)x1.3mm(inside hole diameter) and solder it to where the old one was. Cut that off, use a multimeter to determine polarity and solder the negative to the outside contact and negative to the hole connector. Not terribly complicated but do let us know if you have trouble with that.
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 13
Total : 13
