Device shows up only on DFU Mode, and only shows a black screen
My cousin's iPhone after a long day at her job her iPhone started turning off every few minutes and after one hour of that happening, her screen became black, no Apple logo. When i force restart the phone, i can hear the vibrations but there is no display on the screen, When i plugged it in into my computer, it didn't show anything i tried recovery mode, didn't work, and that's when i entered into DFU Mode, the iPhone showed up and when i went to flash the firmware, it gave me an error code 4013, then i went to use 3rd Party Software to try to flash it, it got at 11% and in the flashing process it said "Unable to switch DFU mode to recovery mode. The software also included something called "Fix Flash" which i used around 10 times and it also kept on getting to 11% which it also said "Unable to switch DFU mode to recovery mode" and i found that you could see more things in the program and this is what showed up.
11:57:44.283: LibVersion: 20231009
11:57:44.283: Start flash
11:57:44.283: Checking PC DiskSpace
11:57:44.283: Detecting Connection
11:57:44.287: Found a device with mode: DFU
11:57:44.287: Detecting ProductType
11:57:44.287: matching device type through original information
11:57:44.290: Checking iDevice firmware C:\3uToolsV3\Firmware\iPhone12,1_17.5.1_21F90_Restore.ipsw
11:57:44.290: Extract BuildManifest.plist
11:57:44.290: Extracting Restore.plist from IPSW
11:57:44.332: Firmware version: 17.5.1
11:57:44.332: Product Build: 21F90 Major: 21
11:57:44.334: Is Image4 supported: TRUE
11:57:44.334: Extracting Firmware
11:57:44.351: Reading ECID
11:57:44.353: Found ECID --------------
11:57:44.353: Reading NONCE
11:57:44.353: Requesting SHSH
11:57:45.017: Enter Recovery Mode
11:58:06.474: ERROR: Unable to connect to device in DFU mode
11:58:06.474: ERROR: Unable to get ApNonce from device!
11:58:06.485: ERROR: Unable to switch DFU Mode to Recovery Mode.
11:58:06.474: Please contact us while failed to fixed 1110 issue.
I don't know what else to do.
