Aller au contenu principal
Pour réparer ensemble - Je crée un compte
My toaster sparked when I used a fork while it was ON
Dear ALL,
I would be grateful if I could get some advice on how to fix my favourite Russell Hobbs toaster. I used it last morning and while I was toasting bread, my son suddenly touched it on its sides with a steel fork while it was still toasting. It suddenly gave a spark and my mains went off(meter tripped). Later, when I tried to switch it ON it did not. Please kindly let me know if something can be done to fix it right or should I give it up. I would love to bring it back into life please.
Any advice/suggestions are great welcome and would be very grateful.
Thank you in advance.
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
1 commentaire
sindu, what model is your toaster?
par
Ajouter un commentaire
4 Réponses
Solution retenue
Check for a blown fuse on your toaster. On those toaster, the fuse is located where the power cable enters the toaster. It should be a 13A BS1362, but that number may be different for different models. Hope this helps, good luck.
Indice 2
4 commentaires:
Hi oldturkey03 ,
Thank you for your very kind reply.
I tried replacing a new fuse last night but no good.
Also, the screws at the bottom of the toaster are of different type that we cannot open with ordinary screw driver. The model number is 13790, 220-240v 50Hz 800w,Russell Hobbs
Any advice woould be very much appriciated.
Thank you
par
Are the screw heads like any of these? http://www.squidoo.com/cool-gift-ideas-f...
par
Take a look on the inside of your plug, that is where the fuse is.
par
Hi Mayer,
Thank you for your time.
One of the screw is of (a) Slotted type but rest of the three are normal ones. Hope this might help to advice further.
Thank you
par
Suggestion: closely examine heating element - may be damaged (burnt) where fork contacted.
Maybe check continuity of element where tester probes can reach - UNPLUG FIRST!
Indice 0
Just a side question. Did he touch the inside or outside of the toaster with the fork? If he touched the outside, the toaster might have a faulty earth, which can cause fuses to keep blowing, but also be a safety risk.
Indice 0
I’d have your electricals checked by an electrician, you might have the neutral and active wires backwards at the point. Side note: Keep kids and cutlery away from the toaster at all times! That might be a lucky kid!
Indice 0
Ajouter une réponse
sindu sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 24
Total : 5,309
