@abcdefghijklmmm this will totally depend on which part was serviced. Since it does not turn on, it appears a power issue. Could be a bad battery or a bad charging board.
First check your charger. Make sure it has proper output. Then check your charging cable. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a USB ammeter and see if your phone draws any amperage from the charger. If it does not it is possible that this is a charging port issue or a bad battery.
To check the charging port, use a voltmeter and measure the voltage on your battery connector. Next plug your phone charger in. Now measure the voltage on your battery connector. That voltage will have to have increased. IF not then the issue is either the charging port or the charging circuit.
Also, never forget to check the flex cables coming from the charging board to the main board. Make sure those are properly inserted and not damaged.
Since iFixit does not yet have a specific guide for this phone, use something like this video Parts are readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@abcdefghijklmmm ini sepenuhnya bergantung pada bagian mana yang diservis. Karena tidak menyala, sepertinya ada masalah listrik. Bisa jadi baterainya rusak atau papan pengisi dayanya buruk.
Pertama periksa pengisi daya Anda. Pastikan itu memiliki output yang tepat. Kemudian periksa kabel pengisi daya Anda. Periksa untuk memastikan konektor tidak bengkok dll. Setelah itu, periksa port pengisian daya. Bersihkan dari kotoran dll, gunakan beberapa hembusan udara untuk membersihkannya. Jika tidak ada yang berhasil, dapatkan ammeter USB dan lihat apakah ponsel Anda mengambil arus listrik dari pengisi daya. Jika tidak, mungkin ini disebabkan oleh masalah port pengisian daya atau baterai buruk.
Untuk memeriksa port pengisian daya, gunakan voltmeter dan ukur voltase pada konektor baterai Anda. Selanjutnya colokkan pengisi daya ponsel Anda. Sekarang ukur tegangan pada konektor baterai Anda. Tegangan itu harus ditingkatkan. JIKA tidak maka masalahnya ada pada port pengisian daya atau sirkuit pengisian daya.
Selain itu, jangan pernah lupa untuk memeriksa kabel fleksibel yang berasal dari papan pengisi daya ke papan utama. Pastikan semuanya dimasukkan dengan benar dan tidak rusak.
Karena iFixit belum memiliki panduan khusus untuk ponsel ini, gunakan sesuatu seperti video ini Suku cadang sudah tersedia di banyak toko online.
Saat Anda menggunakan ponsel, ambil banyak gambar. Setelah Anda selesai melakukannya, ambil gambar itu dan buat panduan untuk iFixit. Itu akan membantu orang berikutnya yang memiliki perangkat dengan masalah yang sama seperti Anda. Sangat mudah dan menyenangkan untuk membuat panduan ini. https://ifixit.com/Guide/new Komunitas iFixit akan menghargai ini.
Perbaikan adalah Perang Melawan Entropi!
A voté
Annuler
Indice
0
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter un commentaire à cette contribution » pour le déplacer.
