Why is my abs light staying on. The brakes are fine
Abs light staying on brakes fine
Accédez rapidement aux tutoriels, aux pièces et aux réponses correspondant à vos appareils
Your brakes are not fine if the ABS light is on. ABS stands for Anti-lock Braking System and is the system that keeps your wheels from locking up under hard braking conditions. The only time you would see the effects of the ABS system is when you slam on the brakes; at that point if they're pressed hard enough to lock them, then you'll feel a shuddering in the pedal that indicates the ABS system is releasing the brake pressure momentarily to let the wheel turn slightly so it's not locked and skidding.
The upshot here is that your brakes are indeed working normally under normal driving conditions, but will not help you out should you slam them on and go into a skid. Here in the US, ABS has only been required on cars since 2013 although Europe mandated it in 2004. So yes, you can continue driving it without fixing the ABS, but you'll be doing without an important safety feature that could save your life.
Generally the most common cause of an ABS light is that one of the four wheel speed sensors has failed or become disconnected. It is possible to test them yourself, but a shop can hook the car up to a scanner and determine exactly why the ABS light is on, which could save you time and money if you know what to replace or fix rather than just guessing.
Hi,
Found this information at mechanic base:
https://mechanicbase.com/brakes/abs-ligh...
It provides a really good description & video of possible causes, you can scroll down to see written explanations.
Hope this helps
لماذا اضاءة الفرامل مشتعلة
English translation:
Why is the brake light on?
Assuming you mean a brake warning light on the dash, the following information was posted over at maxima.org:
The Brake light turns on when the fluid is low or the ebrake is on. In either case, if the fluid is low, you probably need new pads (material wears down, thus resulting in more fluid required to fill in dead volume of absent pad material).
The ABS light turns on when there is a faulty ABS sensor.
Arabic translation:
بافتراض أنك تقصد ضوء تحذير الفرامل الموجود على لوحة القيادة، فقد تم نشر المعلومات التالية على موقع maxima.org:
يضيء ضوء الفرامل عندما يكون السائل منخفضًا أو عندما يكون نظام الفرامل الإلكترونية قيد التشغيل. في كلتا الحالتين، إذا كان السائل منخفضًا، فربما تحتاج إلى وسادات جديدة (تتآكل المادة، مما يؤدي إلى زيادة السائل المطلوب لملء الحجم الميت لمادة الوسادة الغائبة).
يضيء ضوء نظام ABS عندما يكون هناك مستشعر ABS معيب.
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 5
Total : 48
