Aller au contenu principal
7.1 megapixel camera by Canon, model SD750.
9 questions Voir tout
new battery but screen black
when i turn the camera on the lens comes out but the screen stays black brand new battery fully charged
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
1 commentaire
Black screen is caused by a defective high intensity LED strip in the display backlight unit. When these fail you need to replace the backlight assembly
par
Ajouter un commentaire
1 Réponse
Solution retenue
ric, try to hold down the menu key, turning it on and off and resetting the menu options. "Press the "Menu" button. Press the right arrow once to highlight the "Setup" menu. Press the down arrow five times to select "Reset All." Press the "Set" button. Press the right arrow button once to select "OK." Press "Set." from here.
If that does not work,check the flex connector on your LCD. Here is the guide for the LCD screen. You may have to replace the LCD. Hope this helps, good luck
Indice 1
Ajouter une réponse
ric sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 21
Total : 7,636
