If your iPhone 13 Pro is stuck on "Activate eSIM," and you've already tried erasing and updating the phone to the latest iOS version (17.1), here are some things you can check or try:
Ensure your iPhone is connected to a stable Wi-Fi or cellular network. A poor connection can prevent eSIM activation.
Sometimes, the activation process requires carrier support. Contact your carrier to ensure:
- They support eSIM for your specific iPhone model.
- The eSIM is properly activated on their end.
- There are no restrictions on your account.
Try force restarting the iPhone, which can help clear any temporary glitches:
- Press and quickly release the Volume Up button.
- Press and quickly release the Volume Down button.
- Press and hold the Side Button until the Apple logo appears, then release.
You can check if there are any eSIM profiles stuck in the settings:
- Go to Settings > Cellular > Add Cellular Plan.
- If an eSIM is listed but inactive, you might want to remove it and try adding it again.
iOS doesn't display specific error codes for eSIM activation failures, but your carrier can check logs on their end. If there's an issue, they might be able to give more insight.
If there's a network configuration issue, resetting network settings can help:
- Go to Settings > General > Reset > Reset Network Settings.
Sometimes, carrier settings updates are needed for proper network function. To check for any available updates:
- Go to Settings > General > About.
- If an update is available, a prompt will appear.
If you are using a QR code to activate the eSIM, it might be worth requesting a new QR code from your carrier and trying the process again.
If none of these steps work, and the issue persists, there might be a hardware issue with the SIM/eSIM functionality, or a deeper carrier-related problem. Contacting Apple Support or your carrier would be the next step.
A voté
Annuler
Indice
0
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter un commentaire à cette contribution » pour le déplacer.
