Aller au contenu principal
Informations de réparation et de démontage pour l'iPhone SE de deuxième génération, annoncé et mis sur le marché en avril 2020.
20 questions Voir tout
Can I replace the screen and battery at the same time?
I've got an iPhone SE 2020 that needs a battery replacement. The screen isn't in a great condition, but will probably last a bit longer. Since both battery replacement and screen replacement look like bigger jobs, I'm wondering if I can do them at the same time?
It looks like the repair guide for the battery replacement suggests removing the screen - can I just swap the new one in at that step, or is there some extra steps? It looks like I'll need to do something with the home button too.
Has anyone done this, and is there a recommended order of steps combining the two guides?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
Hi,
Yes you certainly can.
just follow the battery replacement guide.
Remplacement de la batterie de l'iPhone SE 2020
Stop at putting the display back on.
When it comes to putting the display back on you can follow the guide for replacing home button guide.
Remplacement du capteur home/Touch ID de l'iPhone SE 2020
Scroll down to where the display is removed and follow the steps to replace home button.
This is where you will remove the home button from your old screen and fit it to the new screen.
Be sure to click in any “blue” comments to see if there’s further advice regarding each step, so you don’t tear the flex and lose Touch ID or home button function.
Hope this helps
Image iPhone SE 2020 Batterie
Tutoriel
Difficulté :
Modérée
30 minutes - 2 hours
Image iPhone SE 2020 Capteur home/Touch ID
Tutoriel
Difficulté :
Modérée
Indice 0
1 commentaire:
This is super-clear! Thank you! I'll try it as soon as the parts arrive!
par
Ajouter une réponse
PCZA sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 11
Total : 62
