Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La série Tecno Camon, axée sur la performance photographique, propose des modèles tels que le Camon 20 et le Camon 19, sortis en 2022 et 2023. Connue pour ses fonctionnalités avancées en photographie et ses performances solides dans le segment des smartphones de milieu de gamme, cette série est particulièrement populaire dans les marchés émergents.
Pour mon téléphone nes allume pa
Pour quoi mon téléphone nes allumé pas
Répondre à cette question J'ai le même problème
Indice 20
1 commentaire
Mon téléphone est tombé dans l'eau depuis l'or s'alume plus
par
Ajouter un commentaire
7 Réponses
Réponse la plus utile
Finalement je me demande aussi pourquoi ça ne s'allume plus ?
Indice 2
@placidnumbi you are not providing enough information. We really would need to know if the phone shows any sign of life. We also need to know the exact model number for your phone.
First you need to check your charger. Make sure it has the proper output. Then check your charging cable. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a USB ammeter and see if your phone draws any amperage from the charger. If it does not it is possible that this is a charging port issue or a bad battery.
To check the charging port, use a voltmeter and measure the voltage on your battery connector. Next plug your phone charger in. Now measure the voltage on your battery connector. That voltage will have to have increased. IF not then the issue is either the port or the charging circuit.
I would suggest to change the charging board. That will include the charging port. The boards are relatively inexpensive and readily available. For more information on how to change it and which board to get, we will need to know the exact model of your phone.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@placidnumbi tu ne donnes pas assez d'informations. Nous aurions vraiment besoin de savoir si le téléphone montre un signe de vie. Nous avons également besoin de connaître le numéro de modèle exact de ton téléphone.
Tout d'abord, tu dois vérifier ton chargeur. Assure-toi qu'il a la bonne sortie. Ensuite, vérifie ton câble de chargement. Vérifie que les connecteurs ne sont pas pliés, etc. Après cela, vérifie le port de charge. Nettoie-le de tout débris, etc., utilise quelques bouffées d'air pour le nettoyer. Si rien de tout cela ne fonctionne, procure-toi un ampèremètre USB et vérifie si ton téléphone tire de l'ampérage du chargeur. Si ce n'est pas le cas, il est possible qu'il s'agisse d'un problème de port de charge ou d'une mauvaise batterie.
Pour vérifier le port de charge, utilise un voltmètre et mesure la tension sur le connecteur de ta batterie. Branche ensuite le chargeur de ton téléphone. Maintenant, mesure la tension sur le connecteur de ta batterie. Cette tension doit avoir augmenté. SI ce n'est pas le cas, le problème vient soit du port, soit du circuit de charge.
Je te suggère de changer le circuit de charge. Cela inclura le port de charge. Les cartes sont relativement peu coûteuses et facilement disponibles. Pour plus d'informations sur la façon de la changer et sur la carte à obtenir, nous aurons besoin de connaître le modèle exact de ton téléphone.
Pendant que tu travailles sur ton téléphone, prends beaucoup de photos. Une fois que tu as terminé, prends ces photos et crée un guide pour iFixit. Cela aidera la prochaine personne qui aura un appareil avec les mêmes problèmes que toi. C'est facile et amusant de créer ces guides. https://fr.ifixit.com/Guide/new La communauté iFixit appréciera.
La réparation, c'est la guerre contre l'entropie !
Indice 1
Pourquoi mon téléphone Camon 19 ne réagit pas
Indice 1
1 commentaire:
[video|7855]
par
Parce que la batterie ne fonctionne plus ou encore il à un 1⃣ problème au niveau de la plaquette
Indice 0
Vérifiez la batterie si c'est chargée tu changes bouton d'allumage
Indice 0
Et quand ça n'affiche que "aucune commande"
Indice 0
camon 40
Indice 0
Ajouter une réponse
Placid Numbi sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 19
Total : 967
