Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Toaster heats but will not pop up.
Modern Maid Built in Toaster KBT100
Répondre à cette question J'ai le même problème
Indice 1
1 commentaire
Work but not poppup
par
Ajouter un commentaire
2 Réponses
Réponse la plus utile
Tom,
Try unplugging it and cleaning all the crumbs out of it either through the slot on the bottom if there is a clean-out or through the top by shaking it vigorously. You might want to do it outside or at least over the garbage since there will be a lot of crumbs and it will be hard to control where they land as they fly out.
Beyond that, if you can take the cover off, use a sponge or an old tooth brush to clean off the release mechanism, which in your case seems like it's sticking.
Perhaps spray a shot of electrical contact cleaner on the moving parts to keep them free to move throughout the rest of the life of your toaster.
Plug it back in and work it up and down a few times before you toast any bread. After that, toast it up and enjoy those eggos!
Frank
Indice 2
If cleaning out crumbs and such doesn't free the pop-up mechanism you may need outside repair. There is a website, Toastercentral.com that sells used KBT-100 Modern Maid toasters when available, and also says they do repairs on this model. You might try contacting them.
Dan
Indice 0
1 commentaire:
Can you not adjust the tension on the springs that pop the toast up?
par
Ajouter une réponse
Tom David sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 18
Total : 7,347
