Aller au contenu principal
Voici comment réparer votre iPhone 14 Pro. Sorti le 16 septembre, le "plus petit" smartphone phare d'Apple est doté d'un écran OLED ProMotion de 6,1 pouces, d'une caméra arrière à triple objectif, de la 5G et de l'encoche interactive Dynamic Island autour de la caméra frontale et des capteurs supérieurs. Successeur de l'iPhone 13 Pro.
20 questions Voir tout
14 Pro display won’t separate from frame
Hello,
I recently purchased a replacement battery for my 14 pro. I'm using the provided suction cup and a hairdryer. After removing the 2 screws, I tried heating the bottom edges multiple times, providing constant pressure, slightly pulling up and down, and also heating while pulling on the display.However I could not get the display to budge enough to get the pick inside. Anyone have this problem, and any tips for the next time try?
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Hi, what i allways do is put some 90% alcohol on the side of the screen to loosen the frame adhesive. Then heat the frame/screen at about 100 degrees celcius and i use a verry thin metal scheed (for example feeler gauges to adjust the contact point of my car engine) i hope you know what i mean, because a rasorblade is a little bit to thick. And put this thin metal sheet between the screen and housing and when there is a small gap i put a drop of alcohol to weaken the adhesive. Sorry for my poor english.
Indice 1
Ajouter une réponse
Arvid Huq sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 4
Total : 16
