Router not turning on and Dim lights Blinking
i have issue with my D-Link , when i switch on my D-Link the router is not switching on and dim lights are blinking in the router continuously. i don't know the issue . can we geta resolution how to fix the issue.
Répondre à cette question J'ai le même problème
Indice 0
1 commentaire:
Does this router use an external power supply and can you measure its output for voltage specified? If power is internal, are you comfortable disassembling it to examine for damage, measure for wall power and rectified (DC) voltage? Power is usually a first consideration. Second is damage to circuitry from power. If not comfortable with disassembly and probing for voltages, consider this as not a diy project without advanced knowledge of electrical and electronic circuits.
par
Ajouter un commentaire
