leaks water out the bottom from internal leak
Keurig B70. Water leaking out the bottom. I removed the bottom plate and observe water inside the unit. Unable to dissemble further without knowledge
This explains how to disassemble, but it's completely unnecessary as you can access the pump seal which leaks by going through the bottom and just unscrew the pump screws to refit the gasket. See other posts on this site.
where do i get the gasket
Links to other posts? I did a search and didn't come up with anything
bill sully, great instructions from here :"You will need to flip your unit on its side for the repair procedure. Lay cloths or paper towels underneath the unit, as it will leak from the K-CUP arm.
Hope this helps, good luck.
when my coffee maker is dispensing coffee into the cup, it does not come out in one stream but several streams causing coffee to leak all over the counter once the drip basked fills up. Is there a fix for this problem as these coffee pots costs quite a bit of money.
Where can i find a repair man in Pikesville Md...
Dernières 24 heures : 2
7 derniers jours : 10
30 derniers jours : 28
Total : 44,581
1 commentaire
I have a k500 series...help
par waterdogdive
