Water damage and a power boost
Mon problème
My I/O board sustained water damage while living in humid environments for the past 4 years, and it had signs of corrosion. The most annoying problem was the intermittent charging. The battery was not in the worst shape (~1200 charge cycles), but since I was opening up the case, I decided to replace it at the same time.
Ma solution
The guide was spot on. No issues at all.
Mon conseil
If you have a compressed air canister, it is a good time to clean the dust that accumulates over the years. Take extra care when dealing with the small connections.
0 commentaires
