Aller au contenu principal
« Retour à Toutes les histoires
Replaced iPad Air Front Panel
maliawaddell -
iPad Air Wi-Fi
Image de l'histoire
  • Image n° 1
  • Image n° 2
  • Image n° 3
iPad Air Wi-Fi Front Panel Assembly Replacement
2 heures
Difficult
Mon problème
My iPad had the ghost touching problem, where it just started freaking out and opening apps without being touched. My research pointed to a digitizer problem. I also had a small cracked screen area.
Ma solution
I had mixed results. Eventually I fixed it. Getting the original screen off with all that adhesive was no joke. I also cracked my replacement screen trying to install the home button and had to order another. The home button still doesn't respond as well as the original. But I have a functioning iPad again! So I'll consider it a win.
Mon conseil
Definitely order the replacement assy that has the adhesive and home button pre-installed. A razor blade and a blow dryer were my main tools used to remove the screen.
Image iPad Air Screen Digitizer
$29.99
1 commentaire
Sounds tricky, but glad you worked it out!
Cynthia Replogle - Réponse Partager
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 11
Total : 159
