Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre iMac Intel 27" EMC 2309 and 2374, utilisez notre manuel de réparation.
  1. iMac Intel 27" EMC 2309 and 2374 Teardown, iMac Intel 27" EMC 2309 and 2374 Teardown: étape 1, image 1 de 2 iMac Intel 27" EMC 2309 and 2374 Teardown, iMac Intel 27" EMC 2309 and 2374 Teardown: étape 1, image 2 de 2
    • We spared no expense to bring you the latest and greatest. We have in our studio the biggest iMac money can buy.
    • The new iMac dwarfs the 20" iMac we took apart earlier this year.
    • The most obvious feature of this new iMac is the new 27" LED backlit display. The display boasts a 2560x1440 resolution, 16x9 full HD.
    • Also in the box is a brand new Magic Mouse. We already tore it apart.
    • Most of Apple's promotional photos show the iMac both running and sans power cord. It looks a lot nicer that way, but unfortunately our unit required the power cord before it would turn on.
  2. iMac Intel 27" EMC 2309 and 2374 Teardown: étape 2, image 1 de 1
    • Nine ports. These are identical to the previous revision, but the Mini DisplayPort has a new trick up its sleeve.
    • This iMac sports a cool new feature that allows you to display video from external sources on the internal display. Apparently, that's to hook up your Blu-ray player externally since the machine still doesn't include an internal Blu-ray drive.
    • Unfortunately, this feature requires an adapter. Where is the adapter? Not in the box. The manual says "Required cables and adapters are sold separately" Not that we're surprised, all you get in the way of cables is a power cable. Yes, Apple thinks cables are from the devil.
  3. iMac Intel 27" EMC 2309 and 2374 Teardown: étape 3, image 1 de 1
    • Like earlier iMacs, the RAM slots are hidden beneath an access door at the bottom of the iMac. A Phillips #2 screwdriver makes quick work of the three screws.
  4. iMac Intel 27" EMC 2309 and 2374 Teardown: étape 4, image 1 de 3 iMac Intel 27" EMC 2309 and 2374 Teardown: étape 4, image 2 de 3 iMac Intel 27" EMC 2309 and 2374 Teardown: étape 4, image 3 de 3
    • You can now install a whopping 16 GB of RAM in your iMac! In a very welcome move, Apple doubled the number of slots, enabling you to install four 4 GB PC3-8500 chips.
    • Naturally, we just had to see for ourselves. Apple's not kidding, if you have the cash, you really can have 16 GB of RAM in your iMac! 16 GB will set you back $1,400 from Apple, or $400 from us.
  5. iMac Intel 27" EMC 2309 and 2374 Teardown: étape 5, image 1 de 2 iMac Intel 27" EMC 2309 and 2374 Teardown: étape 5, image 2 de 2
    Outil utilisé dans cette étape :
    Heavy-Duty Suction Cups (Pair)
    $14.95
    J'achète
    • The new iMac features an edge-to-edge glass. This is different from the 4 mm aluminum bezel that surrounded the glass on the previous iMac. Hopefully Apple's got some pretty strong magnets to keep the glass where it belongs. After upgrading the RAM in our iMac, we noticed the glass was slightly out of alignment on one side.
    • Two suction cups, two steady hands, and the enormous glass panel lifts up.
    • Hopefully you're not following along at home, as this can be a little tricky. If you do have an older iMac that needs surgery, we now have detailed repair guides for many iMac models.
  6. iMac Intel 27" EMC 2309 and 2374 Teardown: étape 6, image 1 de 3 iMac Intel 27" EMC 2309 and 2374 Teardown: étape 6, image 2 de 3 iMac Intel 27" EMC 2309 and 2374 Teardown: étape 6, image 3 de 3
    • The LCD panel is held in place with eight T10 Torx screws.
    • After the screws are free, pivoting the LCD assembly yields the first glimpse of the treasures that lie beneath.
    • Before you can lift up the LCD, carefully disconnect the vertical sync cable from the logic board.
  7. iMac Intel 27" EMC 2309 and 2374 Teardown: étape 7, image 1 de 2 iMac Intel 27" EMC 2309 and 2374 Teardown: étape 7, image 2 de 2
    • The LG manufactured LCD panel weighs in at nearly 11 lbs! Then again, it is a massive 27" beauty.
    • The resolution is a very impressive 2560x1440. That's the same horizontal resolution as a 30" Apple Cinema Display!
    • This display uses In-plane switching (IPS) technology, providing a wider viewing angle and better color reproduction than cheaper Twisted nematic (TN) technology.
    • The panel is very glossy. It's great for spying on those behind you, as well as watching movies.
    • It appears to be model number LM270WQ1. A Google search of that model currently yields five results, and only one of those is in English.
  8. iMac Intel 27" EMC 2309 and 2374 Teardown: étape 8, image 1 de 1
    • This isn't nearly as pretty as the front, but there's some things worth noting here.
    • There are four cables that connect the LCD to the iMac:
    • DisplayPort
    • Temperature sensor
    • LED backlight
    • LED backlight sync
    • The key thing to note is that there's no special shortcut from the LCD to the external Mini DisplayPort connector. The signal will need to go through the logic board, so you'll need to have your iMac powered on if you want to display from an external video source.
  9. iMac Intel 27" EMC 2309 and 2374 Teardown: étape 9, image 1 de 1
    • Ever wonder what was behind that monolithic black display? Here you go: 27" of display-less iMac. (Actually, we're pretty sure the 27" measurement is completely meaningless now that the display is gone.)
    • Notice how the stand is pivoted fully upward. Without the added weight of the LCD panel, there's not nearly enough force against the spring to maintain the normal neutral buoyancy.
    • The hard drive occupies the center of the unit, while the optical drive and fan are clearly visible on the right.
  10. iMac Intel 27" EMC 2309 and 2374 Teardown: étape 10, image 1 de 2 iMac Intel 27" EMC 2309 and 2374 Teardown: étape 10, image 2 de 2
    • Two T10 Torx screws hold the hard drive in place.
    • Once they're removed, the hard drive easily pivots up and out of the system.
    • The 27" iMac ships with a 1TB 7200-rpm Serial ATA hard drive (Apple offers an optional 2TB drive for an additional $250).
    • There isn't really room in here for a second drive, but you could certainly swap this one out yourself. You could hypothetically install an SSD, but this seems like such a good a media computer that it would be a shame to limit it to current SSD capacities.
    • This + that = easy Time Machine internal backup!
  11. iMac Intel 27" EMC 2309 and 2374 Teardown: étape 11, image 1 de 3 iMac Intel 27" EMC 2309 and 2374 Teardown: étape 11, image 2 de 3 iMac Intel 27" EMC 2309 and 2374 Teardown: étape 11, image 3 de 3
    T6 Torx Screwdriver
    $9.99
    J'achète
    • Disconnecting antennas and removing the AirPort Card.
    • A single T6 Torx screw secures the standard PCI-e wireless board to the custom board it's mounted on.
    • Even after removing the silver EMI shield, it's challenging to read the main Wi-fi chip. It's an Atheros AR9280.
    • The two identical chips near the antenna connectors are SiGe Semiconductor 2593A20 power amplifiers.
  12. iMac Intel 27" EMC 2309 and 2374 Teardown: étape 12, image 1 de 3 iMac Intel 27" EMC 2309 and 2374 Teardown: étape 12, image 2 de 3 iMac Intel 27" EMC 2309 and 2374 Teardown: étape 12, image 3 de 3
    • A few screws later, and....
    • The power supply is out.
    • Oooh, pretty colors!
    • Both the blue and red parts are capacitors. Unfortunately they didn't have enough markings on them for us to identify their capacitance.
    • Their Capacitance is 27.5 for both reds, the one blue against the board is 15, and the other two visible blue ones are 20. (all in micro-farads)
    • The power supply puts out 25.8 amps at 12 volts, for a total output of 310 watts. That's the biggest power supply we've seen in an iMac.
  13. iMac Intel 27" EMC 2309 and 2374 Teardown: étape 13, image 1 de 1
    • The Bluetooth board is in the corner of the computer, grounded to the case. We began the removal procedure by disconnecting the blue antenna cable.
    • The board is one of the few components held in place by a T8 (as opposed to T10) Torx screw.
  14. iMac Intel 27" EMC 2309 and 2374 Teardown: étape 14, image 1 de 3 iMac Intel 27" EMC 2309 and 2374 Teardown: étape 14, image 2 de 3 iMac Intel 27" EMC 2309 and 2374 Teardown: étape 14, image 3 de 3
    • This may be the most underwhelming component in this iMac, the 8x SuperDrive.
    • The fact that there is no Blu-ray drive in here is a bag of hurt.
    • C'mon Apple, iMacs in 2005 had 8x SuperDrives. The SuperDrive just doesn't seem so super anymore.
    • The good news is, it's a standard 12.7 mm, slimline SATA optical drive. The drive Apple should have included is this Panasonic UJ-135 Blu-ray drive.
    • Apple lacks software support for playing copy-protected Blu-ray movies, so if you install a Blu-ray drive, you'll have to boot into Windows to enjoy the show.
  15. iMac Intel 27" EMC 2309 and 2374 Teardown: étape 15, image 1 de 2 iMac Intel 27" EMC 2309 and 2374 Teardown: étape 15, image 2 de 2
    • Apple made good use of the extra available space to include large, quiet fans with lots of low speed blades.
  16. iMac Intel 27" EMC 2309 and 2374 Teardown: étape 16, image 1 de 2 iMac Intel 27" EMC 2309 and 2374 Teardown: étape 16, image 2 de 2
    • Removing the massive logic board requires two hands. With the RAM cavity opened underneath the iMac try to help pushing the logic board with the thumb towards the upper part (towards the isight camera), to ease the release of the logic board.
    • Notice how far apart the GPU and CPU are, and how they have separate heat sinks leading to opposite sides of the computer. This rather complex thermal engineering work allowed Apple to upgrade the iMac to use Intel's desktop processors.
  17. iMac Intel 27" EMC 2309 and 2374 Teardown: étape 17, image 1 de 2 iMac Intel 27" EMC 2309 and 2374 Teardown: étape 17, image 2 de 2
    • Apple finally added an SD card slot to the iMac. This may be one of the most inexpensive features Apple could have added, but should prove very useful. Now we can throw away all our USB SD readers!
    • Just one T8 screw secures the slot to the case. The chip is labeled GL137A.
  18. iMac Intel 27" EMC 2309 and 2374 Teardown: étape 18, image 1 de 2 iMac Intel 27" EMC 2309 and 2374 Teardown: étape 18, image 2 de 2
    • Removing the Infrared (IR) sensor needed to use the Apple remote.
    • In the second picture we are removing the central wiring harness and lifting out the logic board.
    • This computer has more linear feet of wire than any iMac we've ever taken apart.
  19. iMac Intel 27" EMC 2309 and 2374 Teardown: étape 19, image 1 de 3 iMac Intel 27" EMC 2309 and 2374 Teardown: étape 19, image 2 de 3 iMac Intel 27" EMC 2309 and 2374 Teardown: étape 19, image 3 de 3
    • Speakers! Big speakers.
    • We tested the sound before we disassembled it, and were quite impressed. Apple has super-sized the iMac's audio in proportion to the increased screen size.
    • While the speakers are in the bottom corners of the iMac, Apple has wisely placed the microphone at the top (near the iSight). That should make it possible to use the internal audio setup for video chats.
  20. iMac Intel 27" EMC 2309 and 2374 Teardown: étape 20, image 1 de 3 iMac Intel 27" EMC 2309 and 2374 Teardown: étape 20, image 2 de 3 iMac Intel 27" EMC 2309 and 2374 Teardown: étape 20, image 3 de 3
    • With the logic board removed, we gain access to a couple of more fans.
    • We removed their screws and rotated each fan out of the computer.
  21. iMac Intel 27" EMC 2309 and 2374 Teardown: étape 21, image 1 de 3 iMac Intel 27" EMC 2309 and 2374 Teardown: étape 21, image 2 de 3 iMac Intel 27" EMC 2309 and 2374 Teardown: étape 21, image 3 de 3
    • I can has heat dissipation? To keep the iMac cool and happy, Apple's included six temperature sensors, three fans, and two gigantic heat sinks.
    • To put the massive size of the heat sinks in perspective, check out the relative size of the USB ports on the bottom left of the board.
    • Notice the PRAM battery on the logic board (circular silver disc) for storing date and time when the power is disconnected. When changing the battery be careful to not to force the plastic top that holds the battery into place.
    • The processor is socketed, but there's a "Warranty void if removed" sticker above one of the heat sink's screws.
    • Our 3.06 GHz E7600 Core 2 Duo processor is a LGA 775 Socket T CPU. There are some Core 2 Quad chips that use the same socket, but we don't know if they would work. The i5 and i7 quad-cores included in the high-end 27" iMac use a different socket, LGA 1156 Socket H.
  22. iMac Intel 27" EMC 2309 and 2374 Teardown: étape 22, image 1 de 3 iMac Intel 27" EMC 2309 and 2374 Teardown: étape 22, image 2 de 3 iMac Intel 27" EMC 2309 and 2374 Teardown: étape 22, image 3 de 3
    • Removing the GPU daughterboard.
    • Our low-end 27" model ships with an ATI Radeon HD 4670 graphics processor packing 256MB of GDDR3 memory.
    • The sheer quantity of labels on the back of the graphic card daughterboard is overwhelming. What were they thinking?
    • (It's obvious that Apple's engineers didn't design that daughterboard. It's a standard card used in a number of products.)
  23. iMac Intel 27" EMC 2309 and 2374 Teardown: étape 23, image 1 de 1
    • Is this an antenna leading into the back Apple logo? We think it is...wonder why?
    • The Apple logo is no longer just for looks, it now has a job to do. Earlier aluminum iMacs had an aluminum front and a plastic back. In contrast, this iMac features an all-aluminum enclosure, which is great for looks, but terrible for Wi-Fi. The Apple logo is the only plastic area on the back of the iMac, and Apple has integrated an AirPort antenna into that space.
  24. iMac Intel 27" EMC 2309 and 2374 Teardown: étape 24, image 1 de 1
    • After such a tedious teardown, you can't blame us for just piling everything up into one ginormous heap of parts.
    • However, curse our guilty conscience, being the nice and awesome professionals we are, we felt an urge and a slight sense of responsibility to do it right.
    • The final layout picture for all to see. Enjoy!
    • If you're feeling this teardown wasn't enough to satisfy your craving, indulge yourself in the Magic Mouse teardown, courtesy of your friendly neighborhood iFixit.
21 commentaires
Cannot wait for the mac mini server teardown.
elurker - Réponse
I cannot wait for the 21.5" iMac teardown comparison to this regarding the mDP video-in capabilities. Great job!!! Very nice and impressive work :)
Vrumm - Réponse
Citation de elurker :
We're not planning on doing a teardown of the Mac mini server (we're already done three teardowns this week), but our friends over at macminicolo.net did a teardown of the new mini.
Luke Soules - Réponse
Awesome pics... I'm craving one of these iMacs, big time.
It wasn't mentioned: what's the brand of the internal HD?
dcp - Réponse
Apple western digital/seagate depending on the location
Tomek Fazlejew -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 19
7 derniers jours : 154
30 derniers jours : 557
Total : 1,110,202
