Aller au contenu principal
1997-2003 Chevrolet Malibu Air Filter Replacement
Ce dont vous avez besoin
  1. 1997-2003 Chevrolet Malibu Air Filter Replacement, Air Filter: étape 1, image 1 de 2 1997-2003 Chevrolet Malibu Air Filter Replacement, Air Filter: étape 1, image 2 de 2
    • The air filter housing is located on the driver side of the car.
    • Loosen the four housing screws on the plastic air intake box.
    • Do not try to remove these screws from the intake box, as they are not designed to be removed.
  2. 1997-2003 Chevrolet Malibu Air Filter Replacement: étape 2, image 1 de 2 1997-2003 Chevrolet Malibu Air Filter Replacement: étape 2, image 2 de 2
    • Loosen the hose-clamp on the air intake tube located on the side of the air intake box.
    • Remove the air intake tube from the intake box.
  3. 1997-2003 Chevrolet Malibu Air Filter Replacement: étape 3, image 1 de 1
    • Gently lift the top off of the air intake box.
  4. 1997-2003 Chevrolet Malibu Air Filter Replacement: étape 4, image 1 de 1
    • Remove the air filter from the housing and inspect it.
    • If it can not be cleaned, then it should be replaced with a new one.
4 autres ont terminé cette réparation.
Sank Yang
Membre depuis le 10/03/12
484 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 9-15, Amido Fall 2012 Membre de l'équipe Cal Poly, Team 9-15, Amido Fall 2012
CPSU-AMIDO-F12S9G15
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 29
Total : 5,329
