Introduction
Recently I installed a pair of Infinity Kappa 10.9t tweeters in my Honda Accord Dx.
The Dx model is notable for having only two speakers stock. Aftermarket rears were already installed years ago, but I wanted to get a bit more sound from up front.
Ce dont vous avez besoin
Use a 10 mm wrench to disconnect the negative battery terminal, followed by the positive terminal.
Gently insert a spudger or flathead screwdriver directly underneath the clock, just enough so you can pry out the clock. Perhaps a half inch or so will do it.
Unplug the smaller connector first. There's a tab on top of the connector that you have to push downwards, then pull the connector. Make sure to grasp the connector itself, and not the wires.
Do the same with the larger connector. Again, there's a tab on top that needs to be pushed downward.
Remove the four screws (two on each side) holding the double-DIN stereo frame in place using a #2 JIS screwdriver or 8mm socket wrench.
There is a small notch on the cover, approximately located by the red box, under which you should insert a flathead screwdriver.
Twist the flathead screwdriver until the cover pops upwards, then work at it from each side if necessary.
Now for the fun part: cutting some wires...
Locate the Left/Front and the Right/Front speaker cables coming out of the radio. There should be two wires for each speaker cable, a Positive and a Negative.
Use a pair of wire cutters to snip-snip those two cables. Don't cut too close to the radio -- make sure that you leave enough length to strip the wire and reconnect it in the following steps.
Take the Left/Front/Positive wire coming out of the radio and twist it together with the same wire going to the tweeter, as well as the one going to the front speaker.
Then, use a wire cap to secure the wires together. Wrap the wire cap and wires with electrical tape.
Do the same for the Left/Front/Negative, as well as the Right/Front/Positive and Right/Front/Negative wires.
Use a piece of cloth to secure the tweeters inside the hole. It will prevent them from rattling around.
Reconnect the car battery and turn on your favorite tunes. Use the fader to switch left-to-right as well as front-to-back and ensure all speakers are functioning correctly.
Adjust your fader. There's much more sound coming from the front of the car after installation.
3 autres ont terminé cette réparation.
