Aller au contenu principal
2003 Toyota Matrix transmission speed sensor Replacement
Ce dont vous avez besoin
  1. 2003 Toyota Matrix transmission speed sensor Replacement, location of sensor: étape 1, image 1 de 2 2003 Toyota Matrix transmission speed sensor Replacement, location of sensor: étape 1, image 2 de 2
    • Transaxle is behind and below engine. You will have a hard time seeing it if your height is less than 170 cm. If you are two metres tall or taller, then it will be easy to see.
    • Some guides instruct to remove air filter, though I find that needless and not beneficial.
  2. 2003 Toyota Matrix transmission speed sensor Replacement, unplug sensor: étape 2, image 1 de 2 2003 Toyota Matrix transmission speed sensor Replacement, unplug sensor: étape 2, image 2 de 2
    • Disconnect sensor now, or disconnect it later. You might find it easier to unplug sensor after removing it from transaxle, when it is less far away from you, then easier to reach.
    • Press on ridged tab to release clip/latch. Grip connector, not wires, and pull it off of sensor.
  3. 2003 Toyota Matrix transmission speed sensor Replacement, remove sensor: étape 3, image 1 de 3 2003 Toyota Matrix transmission speed sensor Replacement, remove sensor: étape 3, image 2 de 3 2003 Toyota Matrix transmission speed sensor Replacement, remove sensor: étape 3, image 3 de 3
    • Transaxle speed sensor is fastened down with one screw, 12mm hexagon head. Use a socket on a long shaft to reach. Just sixteen inches is long enough, also one half yard or half metre works.
    • Observe the dimple in original screws which hold sensor together: these are JIS size 1 cruciform drive. This observation is only meant to be interesting or informative, not relevant to guide.
6 autres ont terminé cette réparation.
unsubstantiated
Membre depuis le 06/07/16
1 066 Réputation
4 tutoriels rédigés
5 commentaires
Wire assignments in piece pictured: yellow is +12 volt, brown is 0 volt, green+white wire is output signal.
unsubstantiated - Réponse
I have a 2003 toyota matrix xr awd and I looked where you told me too and unfortunately the speed sensor was not there. I also bought the manual for it that is for repairs and it showed the same location as of where you were showing and I am dealing with the same problem, no speed sensor.
Victoria West - Réponse
Was easy to fix. Thanks
igbodike - Réponse
2003 Toyota Matrix cruise control light comes on but will not set. Break lights work so think break switch is good. No DTC's. Speedometer works, not sure if speed controlle sensors controller speedometer. Don't want to change sensors randomly but still cheaper than diagnostics labor at garage which they would probably have to change sensors to solve too since no DTC'S. Is there an order of which you would change first? Are steering wheel column switches known to go bad on these? Any other recommendations?
George Murray - Réponse
I have a Toyota Matrix 2004 and when the car is cold the transmission take like 30 seconds to shifting and then go to drive what's going on with my car.
Ixa Rivera - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 66
30 derniers jours : 323
Total : 23,955
