Aller au contenu principal
2007-2013 Toyota Tundra Charging Port Replacement
Ce dont vous avez besoin
  1. 2007-2013 Toyota Tundra Charging Port Replacement, Charging Port: étape 1, image 1 de 2 2007-2013 Toyota Tundra Charging Port Replacement, Charging Port: étape 1, image 2 de 2
    • Remove the switch cover on the left side of the radio by turning it to the "2WD" mode and pulling it straight out.
  2. 2007-2013 Toyota Tundra Charging Port Replacement: étape 2, image 1 de 1
    • Use the plastic pry tool to separate the part of the dashboard behind the steering wheel from the rest of the vehicle.
    • Disconnect the connectors between the panel and the rest of the dashboard.
  3. 2007-2013 Toyota Tundra Charging Port Replacement: étape 3, image 1 de 2 2007-2013 Toyota Tundra Charging Port Replacement: étape 3, image 2 de 2
    • Use your hand to pull out the furthest panel under the radio.
  4. 2007-2013 Toyota Tundra Charging Port Replacement: étape 4, image 1 de 2 2007-2013 Toyota Tundra Charging Port Replacement: étape 4, image 2 de 2
    • Disconnect the wires on the auxiliary power outlets and set the panel aside.
    • You may have to wiggle the connector to get it loose enough to pull it off.
  5. 2007-2013 Toyota Tundra Charging Port Replacement: étape 5, image 1 de 2 2007-2013 Toyota Tundra Charging Port Replacement: étape 5, image 2 de 2
    • Use your hand to pull out the panel directly under the radio.
  6. 2007-2013 Toyota Tundra Charging Port Replacement: étape 6, image 1 de 3 2007-2013 Toyota Tundra Charging Port Replacement: étape 6, image 2 de 3 2007-2013 Toyota Tundra Charging Port Replacement: étape 6, image 3 de 3
    • Use the pry tool to push in the tab on the top from behind and remove the charging port.
    • The tab will be very stiff. It is necessary to use a decent amount of force.
  7. 2007-2013 Toyota Tundra Charging Port Replacement: étape 7, image 1 de 1
    • Disconnect the wires from the rest of the vehicle by pushing in all of the tabs simultaneously and pulling them apart.
    • In reassembly, first feed the wire through the slot of the charging port.
  8. 2007-2013 Toyota Tundra Charging Port Replacement: étape 8, image 1 de 2 2007-2013 Toyota Tundra Charging Port Replacement: étape 8, image 2 de 2
    • Remove the cloth surrounding the wires on the old charging port.
    • Cut the wires near the base of the old charging port.
  9. 2007-2013 Toyota Tundra Charging Port Replacement: étape 9, image 1 de 3 2007-2013 Toyota Tundra Charging Port Replacement: étape 9, image 2 de 3 2007-2013 Toyota Tundra Charging Port Replacement: étape 9, image 3 de 3
    • Use a wire stripper to strip the cover from the ends of all of the wires.
    • Twist the same colored wires and put heat shrink over them.
  10. 2007-2013 Toyota Tundra Charging Port Replacement: étape 10, image 1 de 2 2007-2013 Toyota Tundra Charging Port Replacement: étape 10, image 2 de 2
    • Take some thin heat shrink, cut it in half and put one half on each of the new wires.
  11. 2007-2013 Toyota Tundra Charging Port Replacement: étape 11, image 1 de 1
    • Twist the old and new corresponding wires together securely.
  12. 2007-2013 Toyota Tundra Charging Port Replacement: étape 12, image 1 de 1
    • Solder the old and new wires together so that the black wires are soldered together and the red wires are soldered together.
    • Handle the Soldering iron with caution or you could burn yourself.
  13. 2007-2013 Toyota Tundra Charging Port Replacement: étape 13, image 1 de 2 2007-2013 Toyota Tundra Charging Port Replacement: étape 13, image 2 de 2
    • Put the small heat shrink over the exposed wire and warm it with the heat gun so that it cinches the wires.
    • Do the same with the larger heat shrink.
Ryan
Membre depuis le 09/21/23
217 Réputation
1 tutoriel rédigé
Équipe
Austin Community College, Team 1-7, Watkins Fall 2023 Membre de l'équipe Austin Community College, Team 1-7, Watkins Fall 2023
AUSTINCC-WATKINS-F23S1G7
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 14
30 derniers jours : 77
Total : 254
