Introduction
I wanted a nice sounding horn, so I replaced the stock honkers with a set of PIAA 500hz/600hz "sports" horns.
This guide is a bit of a cheat -- the car was in the shop, and the front body panels were already removed from the car. So to accomplish this at home, you'll either have to finagle your way through the bumper, or better yet, take off the front bumper before embarking on this adventure.
I'll try to include instructions for bumper removal once the car returns from the shop.
Ce dont vous avez besoin
These are the [stock] horns you are looking for. One is located on the left-side of the radiator (when looking at the car), while the other one is next to the air intake / water tank.
Unplug the power connector from the horn, and use a wire stripper to expose a bare portion of the wire. The "20 ga" hole seemed the best fit for this purpose.
Snip about 4" of the ground cable wire (the 1/4" female spade connector side) and use a butt connector to attach it to the horn's power wire.
The factory bolt is a bit larger in diameter than the half-circle connector will allow -- unless it is expanded! So insert a needle-nose plier into the center for the connector and then spread it apart in order to accommodate the bolt.
Route the bolt through the horn's mounting hole.
Screw the bolt / ground wire / horn assembly into the factory mounting hole.
2 autres ont terminé cette réparation.
