Aller au contenu principal
2010-Present Subaru Legacy Rear Door Reassembly
  1. 2010-Present Subaru Legacy Rear Door Reassembly, 2010-Present Subaru Legacy Rear Door Reassembly: étape 1, image 1 de 3 2010-Present Subaru Legacy Rear Door Reassembly, 2010-Present Subaru Legacy Rear Door Reassembly: étape 1, image 2 de 3 2010-Present Subaru Legacy Rear Door Reassembly, 2010-Present Subaru Legacy Rear Door Reassembly: étape 1, image 3 de 3
    • Insert the metal ball into the plastic door pull handle assembly.
    • With the ball inserted, route the steel cable through the assembly and align the black plastic notch on the cable with the plastic notch on the door pull handle assembly.
    • Press the cable notch into the door pull handle notch and snap it into place.
  2. 2010-Present Subaru Legacy Rear Door Reassembly: étape 2, image 1 de 1
    • Hold the door lock in the "unlocked" position with your thumb. This will make it easier to insert the metal ball into the door lock assembly.
  3. 2010-Present Subaru Legacy Rear Door Reassembly: étape 3, image 1 de 2 2010-Present Subaru Legacy Rear Door Reassembly: étape 3, image 2 de 2
    • Insert the metal ball into the plastic door lock assembly.
    • With the ball inserted, route the steel cable through the assembly and align the blue plastic notch on the cable with the plastic notch on the door lock assembly.
    • Press the cable notch into the door lock notch and snap it into place.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 689
