Aller au contenu principal
3DR Iris Plus Quadcopter Propeller Replacement
Ce dont vous avez besoin
  1. 3DR Iris Plus Quadcopter Propeller Replacement, Battery: étape 1, image 1 de 1
    • Power off the drone by holding down the power button.
    • Remove the battery by disconnecting it from the main battery connector.
    • Press the power button again to ensure all electricity is discharged.
    • This step is imperative as it is dangerous to handle drone components with a running current!
  2. 3DR Iris Plus Quadcopter Propeller Replacement, Propeller: étape 2, image 1 de 2 3DR Iris Plus Quadcopter Propeller Replacement, Propeller: étape 2, image 2 de 2
    • Take note of the propeller cap color (either black or silver).
    • Hold down the motor assembly and twist the propeller clockwise to unlock it (you should feel some resistance until it starts to unscrew freely).
    • Hold down the motor assembly and twist the propeller counterclockwise to unlock it (you should feel some resistance until it starts to unscrew freely).
    • This is the motor assembly.
  3. 3DR Iris Plus Quadcopter Propeller Replacement: étape 3, image 1 de 2 3DR Iris Plus Quadcopter Propeller Replacement: étape 3, image 2 de 2
    • Ensure that the propeller cap color (black or silver) matches the propeller screw cap color.
    • There are two different types of propellers so make sure you're using the correct one.
To reassemble your device, follow these directions in reverse order.
Wanjiku Gichigi
Membre depuis le 02/10/20
196 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S7-G5, Regan Winter 2020 Membre de l'équipe Cal Poly, Team S7-G5, Regan Winter 2020
CPSU-REGAN-W20S7G5
5 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 321
