Aller au contenu principal
Pour réparer ensemble - Je crée un compte
8BitDo Ultimate Wireless Button Conductive Pad Replacement
Ce dont vous avez besoin
  1. 8BitDo Ultimate Wireless Button Conductive Pad Replacement, Case: étape 1, image 1 de 2 8BitDo Ultimate Wireless Button Conductive Pad Replacement, Case: étape 1, image 2 de 2
    • Insert an opening pick into the seam between the left controller grip and main controller body.
    • Pry the grip off.
    • Repeat for the right grip.
    Demander à FixBot
  2. 8BitDo Ultimate Wireless Button Conductive Pad Replacement: étape 2, image 1 de 2 8BitDo Ultimate Wireless Button Conductive Pad Replacement: étape 2, image 2 de 2
    • Remove the six 8 mm T6 Torx screws securing the rear case to the front case.
    Demander à FixBot
  3. 8BitDo Ultimate Wireless Button Conductive Pad Replacement: étape 3, image 1 de 3 8BitDo Ultimate Wireless Button Conductive Pad Replacement: étape 3, image 2 de 3 8BitDo Ultimate Wireless Button Conductive Pad Replacement: étape 3, image 3 de 3
    • Insert an opening tool into seam at the bottom of the device and carefully pry the front and back shells apart.
    • Set the halves next to each other with care not to strain the connected ribbon cables.
    Demander à FixBot
  4. 8BitDo Ultimate Wireless Button Conductive Pad Replacement: étape 4, image 1 de 3 8BitDo Ultimate Wireless Button Conductive Pad Replacement: étape 4, image 2 de 3 8BitDo Ultimate Wireless Button Conductive Pad Replacement: étape 4, image 3 de 3
    • The ribbon cable is secured with a locking tab connector.
    • Use tweezers to unlock the locking tab on the ribbon cable connector, then gently disconnect the ribbon cable.
    Demander à FixBot
  5. 8BitDo Ultimate Wireless Button Conductive Pad Replacement, Button Conductive Pad: étape 5, image 1 de 2 8BitDo Ultimate Wireless Button Conductive Pad Replacement, Button Conductive Pad: étape 5, image 2 de 2
    • Remove the seven 5 mm Phillips #00 screws securing the PCB to the top shell.
    • Lift the PCB out.
    Demander à FixBot
  6. 8BitDo Ultimate Wireless Button Conductive Pad Replacement: étape 6, image 1 de 2 8BitDo Ultimate Wireless Button Conductive Pad Replacement: étape 6, image 2 de 2
    • Lift button conductive pads out of the shell with your hands.
    • Replace or clean as needed.
    • If cleaning with water, make sure pads are fully dry before replacing.
    Demander à FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
John Sweriduk
Membre depuis le 04/03/26
85 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 1-3, Biswokarma Spring 2026 Membre de l'équipe UMass Dartmouth, Team 1-3, Biswokarma Spring 2026
UMASSD-BISWOKARMA-S26S1G3
5 membres
5 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 13
Total : 55
