Aller au contenu principal
ANKER SoundCore Battery/Battery Wire Replacement
Ce dont vous avez besoin
  1. ANKER SoundCore Battery/Battery Wire Replacement, Battery/Battery Wire: étape 1, image 1 de 3 ANKER SoundCore Battery/Battery Wire Replacement, Battery/Battery Wire: étape 1, image 2 de 3 ANKER SoundCore Battery/Battery Wire Replacement, Battery/Battery Wire: étape 1, image 3 de 3
    • Use the plastic opening tool to pry off the screen.
    • Remove the screen from the device.
  2. ANKER SoundCore Battery/Battery Wire Replacement: étape 2, image 1 de 1
    • Remove the eight 10 mm Phillips #0 screws from the speaker mount.
    • Remove the speaker mount gently.
  3. ANKER SoundCore Battery/Battery Wire Replacement: étape 3, image 1 de 3 ANKER SoundCore Battery/Battery Wire Replacement: étape 3, image 2 de 3 ANKER SoundCore Battery/Battery Wire Replacement: étape 3, image 3 de 3
    • Remove the two 8mm Phillips #0 screws from the circuit board.
    • Remove the circuit board from its mount.
  4. ANKER SoundCore Battery/Battery Wire Replacement: étape 4, image 1 de 3 ANKER SoundCore Battery/Battery Wire Replacement: étape 4, image 2 de 3 ANKER SoundCore Battery/Battery Wire Replacement: étape 4, image 3 de 3
    • Find the battery below the circuit board.
    • It is covered by fuzz that is the same color as the black casing, so it may be hard to see.
    • Pry the battery off using the iFixit opening tool.
    • Remove the battery from its holder.
  5. ANKER SoundCore Battery/Battery Wire Replacement: étape 5, image 1 de 1
    • Desolder the battery wires.
    • Remove the battery and battery wire from the device.
    • For more information on soldering and desoldering connections, follow this guide.
6 autres ont terminé cette réparation.
Lucas Sandsor
Membre depuis le 02/07/20
283 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S22-G1, Regan Winter 2020 Membre de l'équipe Cal Poly, Team S22-G1, Regan Winter 2020
CPSU-REGAN-W20S22G1
5 membres
6 tutoriels rédigés
4 commentaires
If a bt speaker battery died,the unit can't power up by cable?
limz555 - Réponse
Nice guide… showed how to get the grill off… Unfortunately, my circuit board is epoxied in place.
Battery tests ok, but unit won’t turn on. Its going into the bag with other non-working electronics unless you have any ideas. The little speakers look very nice…
manfred.humphries - Réponse
My Anker works as long as it is plugged in (usb). As soon as the lead is removed, it dies.
David Goodacre - Réponse
Where do I get the new battery in India?
Raghubir Roy L - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 24
7 derniers jours : 130
30 derniers jours : 556
Total : 18,124
