Introduction
Use this guide to test and replace the individual battery cells in your APC uninterruptible power supply model SRT30000XLA.
Ce dont vous avez besoin
Pull the left edge of the front bezel away from the device to release the plastic clip.
Use the cutout in the battery connector to pull it toward the right edge of the device and disconnect it.
Lift and rotate the battery connector to move it out of the way of the battery assembly.
Use a Phillips driver to remove the three 23 mm‑long screws securing the battery assembly.
Pull the battery assembly out of the housing until it stops at its first plastic tab.
Use a Triangle 3 driver to remove the six screws securing the battery assembly's top shell:
Four 22.7 mm-long screws
Two 15 mm-long screws.
Depress the plastic tab above the battery connector and lift up the top shell to release the clip.
Lift the light red wire out of its spot next to the screw post to access the connector beneath.
Grip the white spade connector and pull up to disconnect it from the negative terminal of the battery cell.
Repeat for the other spade connector attached to the positive terminal of the battery cell.
Follow this guide to use a multimeter and measure voltage using these parameters:
If your battery cell's voltage is less than 10 V, replace it.
Charge the entire battery assembly to 100% and test the cell again. If your battery is less than 12 V, replace it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our APC Smart-UPS SRT30000XLA Community for help.
