Aller au contenu principal
ASUS D550MA-DS01 Power Button Replacement
Ce dont vous avez besoin
  1. ASUS D550MA-DS01 Power Button Replacement, Keyboard Module: étape 1, image 1 de 2 ASUS D550MA-DS01 Power Button Replacement, Keyboard Module: étape 1, image 2 de 2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Philips #1 screwdriver to remove the nine screws from the back cover.
  2. ASUS D550MA-DS01 Power Button Replacement: étape 2, image 1 de 1
    • Turn the laptop over and open the display.
    • Insert the flat edge of the spudger into the crease of the keyboard cover.
    • While the spudger is in the crease, carefully pry open the casing by sliding the spudger along the edge.
    • Do not use excessive force to pry open the lid. You should hear each plastic clip snap open as you run the spudger along the edge.
  3. ASUS D550MA-DS01 Power Button Replacement: étape 3, image 1 de 2 ASUS D550MA-DS01 Power Button Replacement: étape 3, image 2 de 2
    • Make sure that the entire cover has been released from the plastic clips.
    • Slowly lift the cover open from the front of the laptop, but do not completely remove it.
    • Note the locations of the three white and blue data cables connecting to the keyboard to the computer's main board.
  4. ASUS D550MA-DS01 Power Button Replacement: étape 4, image 1 de 1
    • If you are only replacing the battery, you can skip this step and the next. Shift the keyboard module away from the display and set it such that the fragile flex cables are not strained.
    • Disconnect the three data cables from the motherboard.
    • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap. Carefully slide the unlocked cable out of the socket.
  5. ASUS D550MA-DS01 Power Button Replacement: étape 5, image 1 de 1
    • Remove the fully disconnected keyboard module from the laptop.
  6. ASUS D550MA-DS01 Power Button Replacement, Power Button: étape 6, image 1 de 2 ASUS D550MA-DS01 Power Button Replacement, Power Button: étape 6, image 2 de 2
    • Lay the keyboard with the key-side down. The circuit for the Power Button is just beneath the location of the button.
    • Unscrew the 2 screws holding the circuit in place, using the Philips #1 Screwdriver.
  7. ASUS D550MA-DS01 Power Button Replacement: étape 7, image 1 de 1
    • Lift upward and remove the circuit board for the Power Button from the Keyboard Module.
Calvin Wieczorek
Membre depuis le 09/16/15
409 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team 1-2, Baechle Fall 2015 Membre de l'équipe IUPUI, Team 1-2, Baechle Fall 2015
IUPUI-BAECHLE-F15S1G2
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 19
Total : 1,266
