Aller au contenu principal
ASUS K43SV SSD Replacement
Ce dont vous avez besoin
  1. ASUS K43SV SSD Replacement, SSD: étape 1, image 1 de 1
    • Disconnect the ASUS k43sv laptop from the external power supply before starting.
    • Place the laptop on a flat table with its back facing up.
  2. ASUS K43SV SSD Replacement: étape 2, image 1 de 1
    • Slide the latch on the right side of the battery on the back of the laptop to the right to the unlocked position.
  3. ASUS K43SV SSD Replacement: étape 3, image 1 de 3 ASUS K43SV SSD Replacement: étape 3, image 2 de 3 ASUS K43SV SSD Replacement: étape 3, image 3 de 3
    • With your left hand, slide the latch on the left side of the battery to the left and hold it.
    • With your right hand, slide the battery out of the battery compartment and place the battery away from the laptop.
  4. ASUS K43SV SSD Replacement: étape 4, image 1 de 2 ASUS K43SV SSD Replacement: étape 4, image 2 de 2
    • Remove the two screws on the bottom of the laptop using a Phillips #0 screwdriver.
  5. ASUS K43SV SSD Replacement: étape 5, image 1 de 3 ASUS K43SV SSD Replacement: étape 5, image 2 de 3 ASUS K43SV SSD Replacement: étape 5, image 3 de 3
    • Slide the hard disk compartment cover towards you with both hands and remove it from the laptop.
  6. ASUS K43SV SSD Replacement: étape 6, image 1 de 3 ASUS K43SV SSD Replacement: étape 6, image 2 de 3 ASUS K43SV SSD Replacement: étape 6, image 3 de 3
    • Remove the four screws from the hard drive support arm using a Phillips #0 screwdriver.
  7. ASUS K43SV SSD Replacement: étape 7, image 1 de 3 ASUS K43SV SSD Replacement: étape 7, image 2 de 3 ASUS K43SV SSD Replacement: étape 7, image 3 de 3
    • Lift the plastic sheet on the left side of the hard drive slightly by hand.
    • Remove the hard drive and its support from the hard drive compartment.
  8. ASUS K43SV SSD Replacement: étape 8, image 1 de 3 ASUS K43SV SSD Replacement: étape 8, image 2 de 3 ASUS K43SV SSD Replacement: étape 8, image 3 de 3
    • Remove the four screws on the side of the hard disk support using a Phillips #0 screwdriver.
2 autres ont terminé cette réparation.
Duanrui Liu
Membre depuis le 09/20/21
279 Réputation
1 tutoriel rédigé
Équipe
York University, Team S-14, Woodhouse Winter 2022 Membre de l'équipe York University, Team S-14, Woodhouse Winter 2022
YORK-WOODHOUSE-W22SSG14
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 31
30 derniers jours : 225
Total : 1,519
