Aller au contenu principal
Pour réparer ensemble - Je crée un compte
ASUS Q405U Battery Replacement
Ce dont vous avez besoin
  1. ASUS Q405U Battery Replacement, Back Cover: étape 1, image 1 de 1
    • Using the Phillips #1 screwdriver, remove eleven (11) 1.5 mm screws from the back cover.
  2. ASUS Q405U Battery Replacement: étape 2, image 1 de 1
    • Pull the back cover off of your laptop. Use a spudger to help pry it off of the device.
  3. ASUS Q405U Battery Replacement: étape 3, image 1 de 3 ASUS Q405U Battery Replacement: étape 3, image 2 de 3 ASUS Q405U Battery Replacement: étape 3, image 3 de 3
    • Disconnect the 4 wires attached from the keyboard side of laptop to the screen side of laptop by pulling them out of their sockets on one end (as shown in picture).
  4. ASUS Q405U Battery Replacement: étape 4, image 1 de 2 ASUS Q405U Battery Replacement: étape 4, image 2 de 2
    • OPTIONAL: Additional pictures to demonstrate moving keyboard out of the way without detaching connections.
    • Lift the ribbon cable with gentle pressure, pry the ribbon away from the motherboard on the right side, then the left, then the center, prying away only a little triangle of tape at a time, applying gentle upward pressure to the tape while you loosen and pry.
    • Once you have enough slack in the three ribbons that hold the keyboard down too tightly, lift the front of the keyboard and twist counterclockwise to produce enough room to reach the screws securing the hard drive with your screwdriver.
  5. ASUS Q405U Battery Replacement, Battery: étape 5, image 1 de 1
    • Using the Phillips #1 screwdriver, remove the four 1.5 mm screws securing the battery to the device.
  6. ASUS Q405U Battery Replacement: étape 6, image 1 de 1
    • Once all screws are removed, lift the battery out from the base of the computer.
For optimal performance, after completing this guide, calibrate your newly installed battery.
2 autres ont terminé cette réparation.
Jeremiah Baselice
Membre depuis le 10/25/21
569 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-8, Sinclaire Fall 2021 Membre de l'équipe UMass Dartmouth, Team 2-8, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G8
4 membres
5 tutoriels rédigés
1 commentaire de tutoriel
I had to remove two other screws from right side where the hard drive is and an extra screw from Step 4 picture. Also I had to remove the wifi card (or the antennas)
Larry Bishop - Réponse Partager
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 23
30 derniers jours : 78
Total : 2,615
