Aller au contenu principal
ASUS Q536F Screen Replacement
Ce dont vous avez besoin
  1. ASUS Q536F Screen Replacement, Back Panel: étape 1, image 1 de 2 ASUS Q536F Screen Replacement, Back Panel: étape 1, image 2 de 2
    • Remove ten 2 mm screws using a Phillips #0 screwdriver.
    • Remove the screw in the center using a T4 Torx screwdriver.
    • Use an iFixit opening tool to pry open the back panel.
    • It's normal to hear some cracking, but proceed with caution.
  2. ASUS Q536F Screen Replacement, Display Assembly: étape 2, image 1 de 1
    • Remove the six 2 mm screws from the hinges using a Phillips #0 screwdriver.
  3. ASUS Q536F Screen Replacement: étape 3, image 1 de 3 ASUS Q536F Screen Replacement: étape 3, image 2 de 3 ASUS Q536F Screen Replacement: étape 3, image 3 de 3
    • Using your fingers, unplug the two power cables connecting the display to the motherboard.
    • Remove the display assembly from the laptop.
  4. ASUS Q536F Screen Replacement, Screen: étape 4, image 1 de 3 ASUS Q536F Screen Replacement, Screen: étape 4, image 2 de 3 ASUS Q536F Screen Replacement, Screen: étape 4, image 3 de 3
    • Potential for device damage: Beneath the screen border is a sticky adhesive. Take your time and exercise caution when removing to avoid damaging it.
    • Use an iOpener to help loosen the adhesive on the screen.
    • Gently pry the bottom right corner of the screen's border and remove the sticky screen cover.
    • Use the opening tool around the entire display to ensure you cut as much adhesive as possible.
  5. ASUS Q536F Screen Replacement: étape 5, image 1 de 1
    • Carefully remove the screen from the rest of the display.
    • The new screen should come with the sticky adhesive.
Adra Ledward
Membre depuis le 09/07/23
557 Réputation
5 tutoriels rédigés
Équipe
Gateway, Team 88-8, Gonzalez Fall 2023 Membre de l'équipe Gateway, Team 88-8, Gonzalez Fall 2023
GCC-GONZALEZ-F23S88G8
5 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 22
Total : 149
