Introduction
Our laptops screen cracked so we needed to replace it. This guide will help you in the process of replacing the display screen for ASUS Q536F. If your screen is damaged in any way, for example, cracked screen, pixels not properly displayed, not displaying vivid colors, or just simple damage being seen, then the entire screen needs to be replaced.
In the process of replacing the screen, take extra precaution, as you are working with a screen and it can shatter. Make sure you take time to wear equipment such as safety glasses. This simple-to-follow tutorial will help users prolong the life of their laptops and replace the screen. Make sure to have the laptop unplugged and powered off before proceeding.
Ce dont vous avez besoin
Remove ten 2 mm screws using a Phillips #0 screwdriver.
Remove the screw in the center using a T4 Torx screwdriver.
Use an iFixit opening tool to pry open the back panel.
Remove the six 2 mm screws from the hinges using a Phillips #0 screwdriver.
Use an iOpener to help loosen the adhesive on the screen.
Gently pry the bottom right corner of the screen's border and remove the sticky screen cover.
Use the opening tool around the entire display to ensure you cut as much adhesive as possible.
