Introduction
The fan is responsible for self cooling the computer during operation. Without a working fan, your computer is prone to overheating and continually shutting down. This guide will help you replace your faulty or broken fan in your ASUS Transformer Book Flip TP500LA.
Ce dont vous avez besoin
Remove the ten 10 mm Phillips #0 screws found on the computer's back case.
Outil utilisé dans cette étape :Heavy-Duty Spudger$4.99
Slide a heavy-duty spudger between the back case and the computer.
Slowly work around the edges to undo the clips to fully separate the back case from the computer.
Gently lift off the back case.
Slide a heavy-duty spudger into the ZIF connector and gently flip up the retaining flap to open the connector.
Pull the blue tab to remove the ribbon.
4 autres ont terminé cette réparation.
