Introduction
If your device is not operating normally or if you experience the blue screen of death (BSoD), it may be time to replace the motherboard. Follow these instructions to replace the motherboard in the ASUS Transformer Book Flip TP500LA.
Ce dont vous avez besoin
Remove the ten 10 mm Phillips #0 screws found on the computer's back case.
Slide a heavy-duty spudger into the ZIF connector and gently flip up the retaining flap to open the connector.
Pull the blue tab to remove the ribbon.
