Aller au contenu principal
ATT CL2940 Buttons and/or Keypad Replacement
Ce dont vous avez besoin
  1. ATT CL2940 Buttons and/or Keypad Replacement, Back Panel: étape 1, image 1 de 3 ATT CL2940 Buttons and/or Keypad Replacement, Back Panel: étape 1, image 2 de 3 ATT CL2940 Buttons and/or Keypad Replacement, Back Panel: étape 1, image 3 de 3
    • Remove five 9.5 mm Phillips #1 screws from the back panel of the phone.
  2. ATT CL2940 Buttons and/or Keypad Replacement: étape 2, image 1 de 3 ATT CL2940 Buttons and/or Keypad Replacement: étape 2, image 2 de 3 ATT CL2940 Buttons and/or Keypad Replacement: étape 2, image 3 de 3
    • Slide the metal spudger into the crack and continue around to the front panel of the phone.
    • Be careful not to break the clips that hold the back panel to the front panel.
  3. ATT CL2940 Buttons and/or Keypad Replacement: étape 3, image 1 de 1
    • When setting the back panel down, be careful to not rip any of the wires off of the internal components.
  4. ATT CL2940 Buttons and/or Keypad Replacement, Buttons and/or Keypad: étape 4, image 1 de 2 ATT CL2940 Buttons and/or Keypad Replacement, Buttons and/or Keypad: étape 4, image 2 de 2
    • Unscrew five 5.6 mm screws on top level, yellow motherboard.
  5. ATT CL2940 Buttons and/or Keypad Replacement: étape 5, image 1 de 3 ATT CL2940 Buttons and/or Keypad Replacement: étape 5, image 2 de 3 ATT CL2940 Buttons and/or Keypad Replacement: étape 5, image 3 de 3
    • Lift the top level Motherboard in order to get to the lower level Motherboard.
  6. ATT CL2940 Buttons and/or Keypad Replacement: étape 6, image 1 de 2 ATT CL2940 Buttons and/or Keypad Replacement: étape 6, image 2 de 2
    • Unscrew the 5.6 mm screw on the clip behind the Screen as shown.
  7. ATT CL2940 Buttons and/or Keypad Replacement: étape 7, image 1 de 2 ATT CL2940 Buttons and/or Keypad Replacement: étape 7, image 2 de 2
    • Unscrew five 5.6 mm screws on the lower level Motherboard.
    • Keep the screws for the upper and lower level motherboard separated.
  8. ATT CL2940 Buttons and/or Keypad Replacement: étape 8, image 1 de 2 ATT CL2940 Buttons and/or Keypad Replacement: étape 8, image 2 de 2
    • Lift the lower level Motherboard upward.
    • Remove the silicon pad above the buttons.
  9. ATT CL2940 Buttons and/or Keypad Replacement: étape 9, image 1 de 2 ATT CL2940 Buttons and/or Keypad Replacement: étape 9, image 2 de 2
    • Push the Button Panel upward and pull it out.
    • Replace the entire Button Panel or a single defective button.
2 autres ont terminé cette réparation.
Charles Messmore
Membre depuis le 02/15/16
541 Réputation
5 tutoriels rédigés
Équipe
IUPUI, Team 1-1, Harley Spring 2016 Membre de l'équipe IUPUI, Team 1-1, Harley Spring 2016
IUPUI-HARLEY-S16S1G1
4 membres
13 tutoriels rédigés
Un commentaire
Great explanation! Where would you recommend buying replacement buttons for the phone? Thanks
Sean Richardson - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 11
Total : 469
