Aller au contenu principal
Acer Aspire 5100 RAM Replacement
Tutoriel Archivé
Ce tutoriel est conservé uniquement à des fins de suivis historiques. Utilisez la version actuelle du tutoriel pour effectuer votre réparation.
Ce dont vous avez besoin
  1. Acer Aspire 5100 RAM Replacement, Battery: étape 1, image 1 de 1
    • Make sure the laptop is turned off and unplugged.
    • Flip the laptop over so the audio jacks are facing you.
    • Unlock the battery by sliding the button (located above the battery) towards the outer edge of the computer. When you feel the battery release and pop up, gently pull the battery from its compartment.
  2. Acer Aspire 5100 RAM Replacement, RAM: étape 2, image 1 de 3 Acer Aspire 5100 RAM Replacement, RAM: étape 2, image 2 de 3 Acer Aspire 5100 RAM Replacement, RAM: étape 2, image 3 de 3
    • Turn over Acer Aspire 5100 laptop so back of laptop is facing up. There are several removable covers, you want to remove the largest cover.
    • Get your screwdriver and remove four screws holding the compartment in place.
    • Slowly lift off backing compartment to expose laptop memory chips.
  3. Acer Aspire 5100 RAM Replacement: étape 3, image 1 de 1
    • Press down the locking levers to release the RAM.
    • Insert the new RAM. (Make sure to insert end with gold conductor end's first)
    • After RAM is put in place, press locking levers to secure the RAM.
iDeleted
Membre depuis le 07/07/10
2 101 Réputation
39 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 3,164
