Aller au contenu principal
Acer Chromebook 14 CB3-431-C3WS Battery Replacement
Ce dont vous avez besoin
  1. Acer Chromebook 14 CB3-431-C3WS Battery Replacement, Back Cover: étape 1, image 1 de 3 Acer Chromebook 14 CB3-431-C3WS Battery Replacement, Back Cover: étape 1, image 2 de 3 Acer Chromebook 14 CB3-431-C3WS Battery Replacement, Back Cover: étape 1, image 3 de 3
    • Remove the two 6mm JIS #0 screws from either side of the hinges.
  2. Acer Chromebook 14 CB3-431-C3WS Battery Replacement: étape 2, image 1 de 1
    • Remove the eight 4mm JIS #0 screws from the back cover.
  3. Acer Chromebook 14 CB3-431-C3WS Battery Replacement: étape 3, image 1 de 2 Acer Chromebook 14 CB3-431-C3WS Battery Replacement: étape 3, image 2 de 2
    • Insert an opening pick between the back panel and the sides of the computer to begin lifting the back off.
    • There are several clips holding the cover in place.
    • After the sides have been lifted, use the opening tool to finish opening the back cover.
  4. Acer Chromebook 14 CB3-431-C3WS Battery Replacement: étape 4, image 1 de 1
    • Lift off the back cover.
  5. Acer Chromebook 14 CB3-431-C3WS Battery Replacement, Battery: étape 5, image 1 de 3 Acer Chromebook 14 CB3-431-C3WS Battery Replacement, Battery: étape 5, image 2 de 3 Acer Chromebook 14 CB3-431-C3WS Battery Replacement, Battery: étape 5, image 3 de 3
    • Remove the two JIS #0 screws that connect the battery to the rest of the laptop.
  6. Acer Chromebook 14 CB3-431-C3WS Battery Replacement: étape 6, image 1 de 2 Acer Chromebook 14 CB3-431-C3WS Battery Replacement: étape 6, image 2 de 2
    • Pull the white tab connected to the battery out of the black tab that connects to the motherboard.
    • It is extremely important that this is done carefully and slowly to avoid causing damage to the motherboard.
  7. Acer Chromebook 14 CB3-431-C3WS Battery Replacement: étape 7, image 1 de 1
    • Lift the battery out gently.
8 autres ont terminé cette réparation.
Samantha Postma
Membre depuis le 10/15/19
1 238 Réputation
6 tutoriels rédigés
3 commentaires
Bonjour vous vendez les batteries CB3-431
mercier-nicolas - Réponse
Vous vendez les batteries CB3-431
Instructions were great. Battery installation complete! I was very glad to find step by step instructions instead of a video. The Chromebook powered up successfully. Now waiting for it to charge. Thank you!
Sherry Chase - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 10
30 derniers jours : 55
Total : 5,492
