Aller au contenu principal
Acer Chromebook 14 CB3-431-C3WS Screen Replacement
Ce dont vous avez besoin
  1. Acer Chromebook 14 CB3-431-C3WS Screen Replacement, Screen: étape 1, image 1 de 2 Acer Chromebook 14 CB3-431-C3WS Screen Replacement, Screen: étape 1, image 2 de 2
    • Using an iFixit opening pick, pop off the bezel from around the screen, beginning on one side and continuing around the whole screen.
    • Remove the barrier from the front of the screen.
  2. Acer Chromebook 14 CB3-431-C3WS Screen Replacement: étape 2, image 1 de 1
    • Starting in the top right of the screen, remove the six 4mm JIS #0 screws that secure the computer screen to the top.
    • There will be two sets of two screws on the top, one screw on each side of the bottom of the screen.
  3. Acer Chromebook 14 CB3-431-C3WS Screen Replacement: étape 3, image 1 de 1
    • Pull the screen down, and lay it flat against the keyboard.
  4. Acer Chromebook 14 CB3-431-C3WS Screen Replacement: étape 4, image 1 de 1
    • Disconnect the input connector from the screen.
  5. Acer Chromebook 14 CB3-431-C3WS Screen Replacement: étape 5, image 1 de 1
    • Remove the screen.
2 autres ont terminé cette réparation.
Samantha Postma
Membre depuis le 10/15/19
1 238 Réputation
6 tutoriels rédigés
3 commentaires
I have horizontal lines that appear for a split second on my screen at random times . Pushing the screen makes the lines appear also. I think I might have dropped my laptop , which may have caused this. Would changing the screen fix this?
aarondhesi - Réponse
Hi, i have the same problem. did it work for you?
Another Backup -
It should! When we looked into troubleshooting this, changing the screen can help with the lines you're seeing.
Samantha Postma - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 15
Total : 3,482
