Aller au contenu principal
Acer Chromebook C720-2827 LED PCB Replacement
Ce dont vous avez besoin
  1. Acer Chromebook C720-2827 LED PCB Replacement, Back Panel Assembly: étape 1, image 1 de 2 Acer Chromebook C720-2827 LED PCB Replacement, Back Panel Assembly: étape 1, image 2 de 2
    • Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
  2. Acer Chromebook C720-2827 LED PCB Replacement: étape 2, image 1 de 2 Acer Chromebook C720-2827 LED PCB Replacement: étape 2, image 2 de 2
    • Pry the back panel open with the plastic opening tool.
  3. Acer Chromebook C720-2827 LED PCB Replacement, Battery: étape 3, image 1 de 1
    • Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
  4. Acer Chromebook C720-2827 LED PCB Replacement: étape 4, image 1 de 2 Acer Chromebook C720-2827 LED PCB Replacement: étape 4, image 2 de 2
    • Carefully pull out the battery wire connected to the battery port.
  5. Acer Chromebook C720-2827 LED PCB Replacement: étape 5, image 1 de 1
    • Slowly lift the battery to remove it from the Chromebook.
  6. Acer Chromebook C720-2827 LED PCB Replacement, LED PCB: étape 6, image 1 de 3 Acer Chromebook C720-2827 LED PCB Replacement, LED PCB: étape 6, image 2 de 3 Acer Chromebook C720-2827 LED PCB Replacement, LED PCB: étape 6, image 3 de 3
    • Use the Phillips #1 screwdriver to remove the two 3.1mm screws from the LED PCB.
    • Lift the LED PCB up with your fingers and flip it over revealing the ZIF connector.
    • The LED PCB is still tethered to the daughterboard via a ribbon cable so be sure not to yank it out or it could cause damage to the cable or its connectors.
  7. Acer Chromebook C720-2827 LED PCB Replacement: étape 7, image 1 de 3 Acer Chromebook C720-2827 LED PCB Replacement: étape 7, image 2 de 3 Acer Chromebook C720-2827 LED PCB Replacement: étape 7, image 3 de 3
    • Set the LED PCB down and use your spudger to flip up the white bar of the ZIF connector.
    • Pull the ribbon cable out with your fingers.
Sarah Westberg
Membre depuis le 03/11/19
23 134 Réputation
70 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
16 817 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 231
