Aller au contenu principal
Acer Chromebook C731-C8VE Keyboard Replacement
Ce dont vous avez besoin
  1. Acer Chromebook C731-C8VE Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Place the Chromebook face down.
  2. Acer Chromebook C731-C8VE Keyboard Replacement: étape 2, image 1 de 1
    • Make sure to completely turn off the device before beginning this step.
    • Use a JIS #00 screwdriver to remove the 11 screws on the underside of the laptop.
    • These 2 mm screws have washers and will be located on the left and right of the device.
    • The 2 mm screws marked orange do not have washers attached and must be placed in these specific areas.
  3. Acer Chromebook C731-C8VE Keyboard Replacement: étape 3, image 1 de 2 Acer Chromebook C731-C8VE Keyboard Replacement: étape 3, image 2 de 2
    • Use the iFixit opening tool to remove the keyboard from the device by prying it loose from the base.
  4. Acer Chromebook C731-C8VE Keyboard Replacement: étape 4, image 1 de 3 Acer Chromebook C731-C8VE Keyboard Replacement: étape 4, image 2 de 3 Acer Chromebook C731-C8VE Keyboard Replacement: étape 4, image 3 de 3
    • Detach the wires connecting the keyboard and the touchpad to the motherboard by lifting the black connectors up.
  5. Acer Chromebook C731-C8VE Keyboard Replacement: étape 5, image 1 de 3 Acer Chromebook C731-C8VE Keyboard Replacement: étape 5, image 2 de 3 Acer Chromebook C731-C8VE Keyboard Replacement: étape 5, image 3 de 3
    • Use the JIS #00 screwdriver to take out the 1mm screw that connects the battery to the base.
    • Detach the battery from the motherboard by lifting it up gently to avoid any damage to the motherboard.
  6. Acer Chromebook C731-C8VE Keyboard Replacement: étape 6, image 1 de 1
    • Remove the battery from the base of the device.
    • Do this step slowly to ensure that you do not damage the battery or the motherboard.
  7. Acer Chromebook C731-C8VE Keyboard Replacement, Keyboard: étape 7, image 1 de 1
    • Use the JIS #00 Screwdriver to remove the four 0.5 mm screws holding the trackpad in order to detach it from the keyboard.
  8. Acer Chromebook C731-C8VE Keyboard Replacement: étape 8, image 1 de 2 Acer Chromebook C731-C8VE Keyboard Replacement: étape 8, image 2 de 2
    • Lift and remove the trackpad to isolate the keyboard.
Sophia Medley
Membre depuis le 02/21/23
106 Réputation
1 tutoriel rédigé
Équipe
1 Guide Comment
Thank you for guide
UMAR RASHID - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 12
Total : 172
