Aller au contenu principal
Acer Chromebook CB5-132T-C8ZW Battery Replacement
Ce dont vous avez besoin
  1. Acer Chromebook CB5-132T-C8ZW Battery Replacement, Battery: étape 1, image 1 de 1
    • Remove eleven 7.2 mm screws from the bottom of the Chromebook using a JIS #1 screwdriver.
  2. Acer Chromebook CB5-132T-C8ZW Battery Replacement: étape 2, image 1 de 2 Acer Chromebook CB5-132T-C8ZW Battery Replacement: étape 2, image 2 de 2
    • Insert and slightly twist a plastic opening tool to separate and remove the backing of the Chromebook from the body.
    • Do not immediately remove the back from the laptop. The power strip keeps the backing attached to the rest of the laptop. Gently lift backing from the power button side and set next to the body of the laptop.
  3. Acer Chromebook CB5-132T-C8ZW Battery Replacement: étape 3, image 1 de 2 Acer Chromebook CB5-132T-C8ZW Battery Replacement: étape 3, image 2 de 2
    • Remove two 4.6 mm JIS # screws at each end of the battery.
  4. Acer Chromebook CB5-132T-C8ZW Battery Replacement: étape 4, image 1 de 3 Acer Chromebook CB5-132T-C8ZW Battery Replacement: étape 4, image 2 de 3 Acer Chromebook CB5-132T-C8ZW Battery Replacement: étape 4, image 3 de 3
    • Carefully pull out the ribbon cable attached to the motherboard that runs wires to the battery.
    • Remove the battery.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 7
Total : 390
